Old 04-10-2010, 03:44 PM   #1
orsm8
orsm8's Avatar
Default Mounting Brackets for Front 4 piston Brembos
Hi Race Brakes, Im after a price on the mounting brackets for Brembo 4 piston calipers. My brembos are mounted in a different position than the factory.My car is an 04 BAXR8 .Cheers
orsm8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2010, 11:59 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Do you have the FG set up on there ? Do you just want the caliper to sit in the same position as the factory set up?
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 05-10-2010, 03:30 PM   #3
orsm8
orsm8's Avatar
Yeah i think its FG, and yes i want the caliper to sit in the BAGTP position.Cheers
Old 05-10-2010, 04:54 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I may have a set here are you in Sydney ?
MATTHEW PEARCE
Phone 02 9609 1101
Old 05-10-2010, 09:57 PM   #5
orsm8
orsm8's Avatar
What makes the FG bracket different? The reason i ask is when i bought the brembo set up i was told they fit BA falcons.It was only when i compared them to a BA GTP that i noticed they were in a slightly different position. Does that make them FG brackets? Thanks in advance. Tony
Old 06-10-2010, 09:53 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The FG brakes are mounted at the rear of the wheel where as the BA BF models were mounted at the front of the wheel. This makes the FG set up when fitted to the earlier models just slightly sitting in a different position but has no effect on braking performance.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-10-2010, 10:08 AM   #7
07TTG
Default Brembos
Hi Matt, So are you saying we BA-BF fellas CAN fit FG brembos to our cars?
Will the brake hoses be OK?
07TTG is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2010, 10:35 AM   #8
FLOORED
Race Brakes Sydney
FLOORED's Avatar
The hoses are different and technically the brakes will fit up but only after you do a few mods to them.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-10-2010, 03:08 PM   #9
orsm8
orsm8's Avatar
Ok so the brackets you have will put my calipers in the BA GTP factory position?
Old 06-10-2010, 03:58 PM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Yes if they are the correct ones and i will try to confirm they are for you.
MATTHEW PEARCE
Phone 02 9609 1101
Old 06-10-2010, 04:50 PM   #11
orsm8
orsm8's Avatar
ok and can you pm me the price.Cheers
Old 11-10-2010, 12:05 PM   #12
azz80
azz80's Avatar
hi, can you please PM me the price for the mounting brackets to suit FG brembos. and whats your price for front 4-spot brembos to suit bf2. thanks.
azz80 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2010, 01:13 PM   #13
FLOORED
Race Brakes Sydney
FLOORED's Avatar
We can't buy the actual brackets seperate for the calipers sorry as they come attatched when we buy the calipers but sometimes we do have customers who like us to try and sell them for them only when we upgrade the brakes for them though . The factory 4 piston brembo calipers with the BF brackets and rubber hoses along with std pads are $1880 a pair thanks.
MATTHEW PEARCE
Phone 02 9609 1101
Old 11-10-2010, 04:25 PM   #14
azz80
azz80's Avatar
thanks for the reply.
so the only way FG brembos will fit my bf2 is if i get the std brackets with them? or can i bolt them up without brackets?
Old 11-10-2010, 05:35 PM   #15
FLOORED
Race Brakes Sydney
FLOORED's Avatar
You can fit the FG calipers and brackets to a BF2 if you like but for them to be as best possible set up as you can get you must swap over the crossover pipe and bleeder nipples and possibly swap them from left to right so the rotor passes the small piston first when rotating as the FG set up is designed to sit at the rear of the wheel instead of the front of the wheel like the BF.
MATTHEW PEARCE
Phone 02 9609 1101
