Can anyone help with:
the temp gauge shows hot when initial startup from cold. temp does not reset to normal. Any help appreciated. |
Formally kotevski22
Remove whirring plug at sender to see if that will drop the gauge.
sender is at the back of the head, you can see it from the drivers side
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
