Guys
Have a June 02 S3 6 cylinder duel fuel sedan. What types of plugs do you recommend for gas? FYI - I change the oil + filter every 10k & looking at the plugs at 20k? Cheers ![]() Last edited by Erich; 27-05-2010 at 09:28 AM. |
Flairs - Truckers Delight
NGK BPR5EY
tree-fiddy each and they do the job excellently. 20k is too often (waste of money), 30k is fine.
#3 | |||
![]() Had NGK BPR6EY's in them but will do the 5's ![]() And gap - set to 0.9mm? |
Nah
i think you will have had BPR6EY-11's the suffix indicates the gap in tenths of millimetres (ie 11 = 1.1mm) a lack of suffix indicates the default gap of 0.8mm which is juuuust right for LPG
ah i've got it round the wrong way
BPR5EY-11's is what the petrols take BPR6EY is what you want for gas sorry mate
kewl - so it had the correct ones in it (BPR6EY). Will replace with same then gap at 0.8mm and it should
