where is the A/C drain tube inside the car? i can see it in the engine bay, but cant find it inside. i went a bit quick around a left hander today
Not sure about the A/C, but have you checked the spot-welds below the windscreen washer motor?
I siliconed mine up not long ago and haven't had any water droplets land on my feet since.
FPV GS Ute #370/Brembo brakes |
#3 | |||
Cat be Still !!!
amiers, Was it or had it been raining? |
no rain. but did wash the car in the morning. checked today after driving and the normal amount of water was coming out of the drain under the car. it was only a drop or 2 inside the other day but it was icey cold. mind you i went around the corner very quick.!
It's worth a check, I only noticed mine after a wash too.
Steve
Stick some wire up the drain tube it may be partially blocked and backing up the condensate( water).Easy fix first.
Currently no Fords . 2005 Statesman International 5.7, Mazda 2 and a Hilux. Former Fords: 2010 Ford Escape 2007 BF11 GT, TE50 Series 1 ,AU V8 One Tonner ,EL Falcon Wagon, ED Fairmont , EB Falcon Series 1. Mk 2 Cortina Company Fords : 3 BA Falcons , EB 11 Falcon Wagon , Ford F350 351 V8. |
