Lost Boost Gained Class
hey guys i cant find a step by step on how to remove the drive belt mine needs replacement and i dont know how to remove the old one Thanks
2006 BF Fairmont Ghia
2001 AU Falcon |
Hi there, you will need a 3/8" driver. This can be put into the hole on the front of the tensioner pully which has two pulleys on it and is just above and to the left of the airconditioner pulley. You can then turn the driver anti-clockwise which will release the tension and you should then be able to slide the belt off. Same can be done in reverse.
It is probably easier if you get someone else to slide the belt off as the tensioner can require a lot of force to release. Hope this helps Cheers, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
gone fishing
have a look through here http://www.fordforums.com.au/showthr...highlight=belt
the search function is your friend hope this is waht you wanted cheers
Cheers Whiskers |
yeah i looked at that link just after i posted ill give it a try later today
2001 AU Falcon |
#5 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
And here"s a picture of how it goes back on .just incase yours has gone from under the bonnet
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
