Hi,
I have a '99 VCT XR6 VCT 100,000km, I've doen some mods, including SS induction with K&N panel filter, also a redback 2 1/2" cat back exhaust. Also 17" BSA 265 shadow chrome rims with slotted rotors and Lucas pads. Thats the good stuff, now for my problems. When ever it rains, I constantly get water dripping into my driver foot well, I've taken it to the mechnic twice and he has replaced the front windscreen and put new seals around windcscreen windscreen, also plugged up some holes in the suttle pan, about $500- latter vehicle is still leaking, wondering if anyone has had this problem and knows how to fix it or who can fix it, Also wanting to lower my vehicle, I leaning towards whitelines "THE WORKS" suspension pack including camber kit and strut braces, mainly to lower the ride, better feel and wanting to correct some understeer concerns with the AU. Wonderin if anyone can recommend any other suspension set ups and what prices they have got it done for or who has this setup and what they have to say about it Last edited by Red Baron XR6 VCT; 27-05-2005 at 05:19 PM. |
Miami Pilot
![]() Join Date: Jan 2005
Red Baron - try sending a PM to either Dark_Horse or Strider. I'm sure at least one of these members has had problems with water leaking into the footwell, so they should know how (and if) it can be fixed.
As for suspension, IMO, you can't go past Konis with king lows or superlow springs. Strut brace is not really required, but a camber kit (shim type) is recommended.
buickman
Since you have tried most obvious places to try to stop the leak then it might be the door seals or the car has had a front hit somewhere along the line and has opened up a crack or panels not fitted up correctly.
buickman |
water leaks really suck they can be so hard to find, the way i was shown to check door seals was to put a smear of vaseline around the seal then close the door and open it, if there is a spot where the rubber is not sealing it will show up usually, i can remember doing water leaks years ago sometimes involving removal of trim ,seats ,carpet,glove box, console and getting a helper to slowly run a hose on door jams from bottom up while i layed in car with a torch checking to see where the water was coming in, also up under gaurd, on firewall and down vents , and last the windscreen a common one used to be where the aerial cable comes in, i would have a good look around the rubber grommets on firewall and last ,if you do the water thing you have to take your time because sometimes when the water comes in it takes a while to run down, if nothing else shows up check screen again wouldnt be the first time a screen has been resealed without good results,try the easy stuff first , hope you dont have to do all that good luck
Is your car manual?
Neil
HSV I JUST BEAT ONE! 03 XR6T lighting strike auto prem sound 19's 383.9rwkw ![]() 96 EF series 2 XR8 sedan manual |
#6 | |||
XB in parts...
Its quite annoying.
Daily Driver 2019 Ford Escape...looking for XR6T's. |
Sorry to tell you this boys but your firewall is probably cracked, my brother had this problem in his 98 AU manual the firewall split on the weld where the pedal box mounts cost him 1500 for ford to pull the dash out and send it to a pannel beater to get welded up. Ford said it's a common problem with AU manuals but not one that warrents a factory recall.
Neil
XB in parts...
Well thats :ymca: news if it's actually what the problem is.
If we took the car to a panel beater would it be easy to spot ?
it should be you could probably check yourself stick your head under the dash and get someone to hose the windscreen you'll be able to see it coming in.
Neil
Thanks for all your help regarding this, I will carry out the tests and get back to you with a solution (hopefully).
Niel101, yes my car is a manual, |
#11 | |||
XB in parts...
#12 | ||
LoxXr6, mines the same, I think cause I park on a hill it effects it worst, but is urs still dripping. I've looked up into the footwell and found that it drips from just over the brake pedal, but I can not locate exactly where it is coming from. My major concern is the underlining of the car, and possibility of rust occurring under the lining.
#13 | ||
XB in parts...
Its just a really slow drip. It doesn't happen straight away but its annoying none the less.
#14 | ||
Been there, done that (bloody f$%ken annoying)!!!
The problem with mine was that there were cracks in the scuttle panel where the steering box attatches from underneath. The cracks are visible if you remove the plastic grill thing near the windscreen wipers (they may be tiny). The water gets in these cracks. When you accelerate or go uphill the water will come down onto your feet! This needs to be welded - apperently with dash out, which cost me big bucks done at Ford, Courtney & Patterson Ford botched this badly. I had it back there about four times, because ever since I have had a bit of engine noise coming from the engine bay into the cabin!!! Ford couldn't fix the problem! I eventually fixed this myself after much agony. --------- The cracked firewall is a seperate issue which I also had, but this dosn't result in any water getting into the cabin. Also needs welding!!! Bloody hell! Writing about all these past dramas really makes me sick! Luckily my car has been without problems since then. Good luck..... // Jake |
#15 | ||
Thanks Jake,
Worst thing ever, hey your not the guy with the black xr, lowered wheels, sounds nice tinted windows are u? Yeah, know what you mean about Courtesy and Patience, took mine there and they tried to tell their nothing wrong with it. And that they couldn't find any problems, took it to MI Auto in Bulleen, they did a great job, and replaced windscreen and all seals and rubbers, also sealed up some holes in the skuttle pan but water leak almost stopped but still slightly there. Absolut pain in the ****, and just want it to stop, as I have to replace my carpet, due to the smell it has created. Last edited by Red Baron XR6 VCT; 31-05-2005 at 06:19 PM. |
#16 | |||
buickman
I nearly got rid of my AU when the ball that connects the boot strut snapped of and Ford would not come to the party because out of warranty. If mine started creating water probs like that It would **** me of big time and end up selling the car. buickman |
#17 | ||
i had the water leak issue with my au2 xr6, after i sold it my mechanic mate told me a rivet comes loose under the scuttle panel and requires a bit of silicone sealant and says he has fixed about 3 AU's this way. mine gushed on my foot in the rain just after i reversed out my driveway. my currect AU doesn't leak so never checked if this is acutally the case.
regarding the suspension upgrade. i just love the ride on my old 150,000km xr6 hp with stock suspension and now in my xr8 i have new selby springs and new ultima shocks (shocks are way to soft) so koni or bilsteins are the only way to go. bushes should be ok with only 100,000km on it so just a camber kit and aggressive wheel alignment to fix the understeer get one from a performance suspension shop like "east coast suspensions at kirrawee NSW" not a tyre shop they usually have no clue about a good setup
CURRENT RIDES BA GT Mk1 #0009 - Narooma Blue SY Ghia AWD Black VZ LX8 Adventra Holden HX 50th Anniversary AU Saloon Car racecar 1980 GS1000ST - Wes Cooley Rep
#18 | ||
i got a manual au3 aswell, i also get the leak on the foot its noramally above the break pedal what is the scuttle pan?
#19 | ||
BOSS Pilot
Ive had this problem as well, the main reason i can see from what i have read is that the firewall is cracked as others have said, but can it be fixed from the outside, without the dash appart?? Mine is a manual, but will leak if left up hill, as the water pools i think or sometimes slightly when it is level. Having to remember to park downhill is a pain.
cheers
09 FPV SUPER PURSUIT Manual, DF BIG BOY, Coilovers, BPR CAI, Tune, Rims and much more... 2011 KTM 300 EXC Previous Rides 05 BA MKII XRT 04 WR250F 06 BF XR6 5 SPD 02 AUIII XLS 5 SPD
#20 | ||
Critical Thinker
geez, thread mine much??? :P
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#21 | |||
Getting it done.....
Where does the radio aeriel cable come in on an AU? Had a leak in the old mans XD years ago and all it was was a missing grommet on the radio aerial wire. The water used to trick down along the wire and then drip off into the passenger footwell. Bugger to find it but quite a laugh when we did. Bit of silicon bobs your uncle.
Dynamic White 1995 EF XR6 Auto Now with: Pacemaker 4499s Lukey Catback Exhaust Chrome BA XR-style tip Airdam Mounted CAI with modified (bellmouth) airbox Trip Computer install KYB shocks Bridgestone Adrenalin tyres Coming Soon: Exhaust Overhaul..... |
#22 | |||
You can't stop the signal
Try this first. It has been the issue for a few guys
http://www.fordforums.com.au/showthread.php?t=11220972 Cheers
