26-06-2009, 04:13 PM | #1 | ||
Rusticating
I just wondered what methods ppl use to access the underside of their AUs? I have 4 hardwood sleepers that I've cut into ramps so I can get about 5 inches of lift with the car level. I can then crawl underneath, but I'd really like more elbow room and clearance for a creeper. I'm considering investing in a trolley jack and a second pair of axle stands. Is it safe to get under a car on 4 axle stands? Is it safe to jack on the alloy front crossmember? Maybe with a block of wood?
PS: Just did a search on 'jack crossmember' and it seems it's one of those things that's risky but a lot a ppl do. (And expressly forbidden by Ford.) So let's not reopen that can of worms. Bit of a pain having to jack each side separately though...
Territory SYII RWD, BFII RTV tray |
26-06-2009, 04:29 PM | #2 | ||
ROCKING THE EL FUTURA
car ramps mate.
i jack it with a troley jack then put the front on the ramps. but if i need full acces to the rear i jack that on car ramps as well. it pays to have four of them. and two troley jacks.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
26-06-2009, 04:31 PM | #3 | ||
to jack it from the front i put the jack on the cross member with a block of wood.
and the back i jack it from the diff.
26-06-2009, 04:34 PM | #4 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
26-06-2009, 04:57 PM | #5 | ||
Giddy up.
I have a BIG heavy duty trolley Jack and car stand's, they a built like a brick sh#*house,
I don't go cheap when safety is a major concern. |
26-06-2009, 05:10 PM | #6 | ||
All Bran = Regular Member
I bought a second 1900kg trolley jack a little while ago.
With two jacks, four stands + ramps I've just about got it covered. |
26-06-2009, 05:27 PM | #7 | |||
GT Hardcore
BF GT - 6spd ZF Auto - 292.8 rwkw 1/4 mile 13.385@ 108.32mph @ Willowbank 5/03/11. in Qualifiying STREET SERIES ROUND 7 http://www.fordforums.com.au/showthread.php?t=11295036 Cragsted Race Engines -http://cragsted.com.au/ BPR CAI , PACEMAKERS 4-1, BALLISTIC 100cell RACING CATS, CROW CAMS GTP, K LINE , XFORCE ,PSI VALVE SPRINGS, MANLEY H BEAMS, SRP PISTONS & RINGS, ACL RACE BEARINGS MELLINGS BILLET OIL PUMP, POWERBOND UNDERDRIVES, TT1-160 THERMOSTAT. |
26-06-2009, 05:45 PM | #8 | |||
Do a search with IRS + Jacking for more
26-06-2009, 05:56 PM | #9 | ||
yeh no dont go by the diff if you have irs.
26-06-2009, 05:57 PM | #10 | |||
Giddy up.
26-06-2009, 09:10 PM | #11 | ||
i have some railway sleepers also , gives me about 5/6 inches so i can get the 2t jack under, i also have a couple of bits of 30 x50 mm tube welded side by side approximatly 600 mm long with a keeper welded on one end so it can`t slide , it also has a piece of steel rod welded to the under side of it in the middle to locate it in the jack, i remove the lifting plate off the end of the jack and sit the steel paralel to the jack and use the alloy x member and front steel x member......it looks a little ugly but its effective , it gets the car up about 600mm to sit on 3 ton stands and shares the load on 2 x members.
27-06-2009, 01:26 AM | #12 | ||
Miami Pilot
I use the front cross member, but you have to have the jack towards the back of it or it slips off (guess how i found that out????).
Also, you can jack on IRS rear using the cradle, which is just behind and above the diff.
27-06-2009, 10:13 AM | #13 | |||
Rusticating
Another option I was considering is the display ramps car yards use, like this: (ebay link) My concern is that with no height adjustment, you could end up at the wrong height for some tasks and be no better off. For the price though I'd buy 'em if they were in my state.
27-06-2009, 11:36 AM | #14 | ||
yes the tubes run inline with the engine , should you do this you need a keeper because its on a slight angle and metal on metal is slippery, but it works quite well as long as your on sleepers or already up a bit off the ground, nice ramps in the link .... if you can get them for the right price would be very handy, agreed on the wrong height at times, but for a lot of jobs or quick inspection under the whole car it would be great i think.
27-06-2009, 01:00 PM | #15 | ||
Which is the best way to lift the rear of my XR safely????
I looked at the front end and noticed its made of alloy.. is it even safe to use the trolly jag to lift the front...???????? I want to adjust the hanbrake cable and have a good look underneath the car... Help!!!! |
27-06-2009, 08:36 PM | #16 | |||
Miami Pilot
28-06-2009, 06:45 AM | #17 | ||
SKID IT
my jack pulls it up high and have big jack stands, not little supercheap ones, brings it about a foot from the ground when the stands are on the lowest point
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
28-06-2009, 08:57 PM | #18 | ||
a hoist
2009 FG turbo ute 1983 Toyota sprinter- quick/fun car with a Nissan heart 2010 CRF250- when I want to get dirty |
29-06-2009, 04:08 AM | #19 | ||
Not a bad idea Dusty86...
That way i can have a good look the best way to jack the car up.. |
29-06-2009, 12:39 PM | #20 | |||
Rusticating
30-06-2009, 02:07 PM | #21 | ||
workshop and pretty relaxed boss
30-06-2009, 03:17 PM | #22 | |||
You adjust your handbrake inside the rear wheel hubs not by the cable, don't ask me how but cause I haven't had to do mine yet.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track. 86 ZL mint grandpa spec with premo sound and 150000km 07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4! 97 el futura MOCKed up with a 2500 stall, heaps of fun! |
