27-07-2008, 06:28 PM | #1 | ||
Hi all, Recently picked up an 06 LS Hatch, great vehicle, however I noticed that I get a water leak on the passenger side in the boot.
I am guessing it is getting in around the tail lights? Anyone got any idea's? I gather its a common problem, was hoping for a pointer in the right direction so I can fix it myself....not keen on having ford was a day.... Cheers Zane |
27-07-2008, 06:51 PM | #2 | ||
proud member of the MFCC
is it a focus or fiesta !
27-07-2008, 07:01 PM | #3 | ||
That would be a LS Focus
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
27-07-2008, 08:09 PM | #4 | ||
opps - sorry it a 06 Focus. I figured it may need a squirt of silocine somewhere....
28-07-2008, 09:59 AM | #5 | ||
Yes it's very common. I've seen it on 5 out of 5 Foci's that I checked.
I was told by a Ford mechanic that it's a design fault and (quote) ' Ford really should do something about that'. It doesn't leak a lot, but it is unacceptable in a new car and will probably cause water damage over a period of time. My LS went to the panel beaters 5 times and still wasn't fixed. I just gave up. It started to stink after abot 8 months of ownership. My new LT Zetec also leaks a little in the same place, I couldn't be ****** doing anything about it. |
28-07-2008, 12:44 PM | #6 | ||
yum
I've ran without any boot trim trying to work out where its from. Its could be letting water in from the rear quarter glass or the roof rails.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
28-07-2008, 03:06 PM | #7 | ||
Eat my Brake Dust
OK i had this leak and fixed it. take off both tail-lights and in the top corner you will notice the roof panel and side panel overlapping. It is here i found that the welding was not done correctly and left a gap of about 5mm wide and 2mm high. water pours through there, down the inside of the piller and then drops into the boot. left side was the worst (looking from back to front). sealed the gap with salley's no gaps and i haven't had a problem since.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club If I'm going to Hell, I'm going in a Ford |
28-07-2008, 06:30 PM | #8 | ||
thanks Guys - appreciate the advice. I pulled the tail light off and couldnt see anything obvious - everything was well sealed.
I should note I have only noticed the issue after going thru a car wash - with high power jets. Havent seen it leak in normal rain (touch wood). I have a hunch it may leak in around teh quarter glass. But I put a little silcone over/around the screw holes that hold the tail light in - they looked like an easy spot for water to get in. time will tell..... |
29-07-2008, 01:19 AM | #9 | |||
Here is the same problem taken from ffoc.co.uk.
29-07-2008, 01:27 AM | #10 | ||
Zoom Zoom
Nice post Biggs, thank you.
2012 Mazda3 MPS
29-07-2008, 09:31 AM | #11 | ||
Biggs, we are talking about water leaking into a closed boot on a parked car, though a gap somewhere.
What you are describing is water pooling under the rear window, then running into the boot when the hatch is opened. I think the Mondeo had the same problem. Two different issues, but thanks for the info. Last edited by scooby; 29-07-2008 at 09:33 AM. Reason: spelling |
