22-06-2007, 02:57 PM | #1 | ||
I have an AU1 Futura wagon fitted with duel fuel.
For some reason it has started using excessive petrol. I can't get better than 16l/100km used to get 10l/100km or better on a long run and 12 to 13l/100km around town. Had it back to Ford and they said nothing is wrong with it. Had injectors cleaned, new plugs, plug leads, new oxygen sensor and aircleaner, still no good. It starts good when cold but hard to start when its warm and puffs black smoke when it starts. Any Ideas what might be wrong. |
22-06-2007, 03:58 PM | #2 | ||
www.TUFFCARPARTS.com
Did it just suddenly get worse or gradually?
Is that consumption figure on gas or petrol? Have you just recently had the gas conversion done?
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
22-06-2007, 06:01 PM | #3 | ||
Miami Pilot
Sounds like Map sensor under the TB could be stuffed.
22-06-2007, 07:42 PM | #4 | ||
No it suddenly got worse, its not a new gas coversion its been on the car 7years. the fuel consumtion figures are for petrol
22-06-2007, 07:44 PM | #5 | |||
22-06-2007, 07:58 PM | #6 | |||
Blown 5L coming
o2 sensor, fuel filter and t/b clean. check these are all ok first.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
22-06-2007, 08:02 PM | #7 | |||
Treasure your balls?
Meteorite T3 TS50 ESS |
22-06-2007, 09:00 PM | #8 | ||
^^ 2/3rds right... manifold absolute pressure, checks the air pressure in the intake manifold and adjusts how much fuel to put in
22-06-2007, 10:42 PM | #9 | ||
Karasu
I'd certainly be looking at the MAP sensor but check the intake manifold gasket as well, they are notorious for working loose
