Old 04-02-2007, 03:49 PM   #1
n0n1ckname
Default 94 Telstar Ghia Braking problem
Hi all,
New here so please be nice, i have a 94 Telstar and am having a problem with the brakes
Whilst driving the 4wabs light on the dash turns on and occasionally the brakes start to lock up when you stop and the car doesnt really stop very well
does anybody now what could be causing this ?
Thanks for your help
n0n1ckname is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2007, 04:48 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
replace the brake fluid
a ceasing caliper or warped rotors
get them checked by a brake specialist
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 11:03 PM   #3
crankyTX5
Disk rotors tend to warp easy on these babies, good idea to check them out.
crankyTX5 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 11:37 PM   #4
carazy
Back with Boost!
carazy's Avatar
Brake fluid is unlikey to be the cause but if it hasn't been changed in a while it's a good idea (and a bastard to do if you get an air bubble in the hydrolic clutch)
Firstly the 4ws light comming on means the fluid is low or the hydrolics have failed.
Jack the car up and check for leaks around the rubber boots and check the system is working by turning the wheel to full turn and looking at the rear.
Also as far as locked up brakes, your (most likely rear) calipers are seized on. There is a fault in the mazda626/telstar that causes the handbrake to lock the rear discs. This intern may well cause your rotars to warp.
carazy is offline   Reply With Quote Multi-Quote with this Post
