Old 11-01-2007, 10:11 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Removing redback exhaust - EL sedan
Hi All,
I'm currently removing a Redback exhaust from an EL sedan that I'm wrecking. I know how to remove it, but the whole exhaust is 1 piece from the cat to the tail pipe, so just wondering where I am best to cut it, so I can get it out?
I only ask, as I want to cut it in the best place for it to be welded again once it's fitted to my EF.
Thanks,
Justin.
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 10:23 PM   #2
Skooter
Skooter's Avatar
if there is a resonator cut it where that joins into the pipe, try and find some 1mm grinder discs they work a treat and come in handy in many situations.
Skooter is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 10:30 PM   #3
Interceptor'85
Interceptin'
Interceptor'85's Avatar
Why do you need to cut it? I'd leave it in one piece and unbolt it.
'95 EF II Falcon,
'INTERCEPTOR'
'72 XA Fairmont Coupe,
'XA Muscle'
Interceptor'85 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 11:13 PM   #4
private9
private9's Avatar
I didn't think it was possible though to remove it in one piece without dropping the diff out?
Old 11-01-2007, 11:28 PM   #5
atec77
jack it up HIGH
atec77 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2007, 11:43 PM   #6
private9
private9's Avatar
Originally Posted by atec77
jack it up HIGH
When you say that, are you saying jack up the body, not the diff? Have you managed to get an exhaust out this way?
Old 12-01-2007, 01:27 PM   #7
Lil Regy
Posts: n/a
does it have any mufflers or resinator
Old 12-01-2007, 01:43 PM   #8
Damo
best place to cut it would be before the diff. Unless you can get it on a hoist or feel like dropping the diff then you will have to cut it.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 01:59 PM   #9
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
Undo drivers side rear shocker jack body right up and you will be able to manouvere the complete system out.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping".
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 03:18 PM   #10
needfordspeed
Your wrecking it right? Tip the thing on it's side and it'll be easy
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2007, 04:40 PM   #11
Lil Regy
Posts: n/a
if u gotta cut it make it on one of the least supportive sections
Old 13-01-2007, 01:20 AM   #12
private9
private9's Avatar
Only the 1 muffler up the front - nothing at the rear section.
I think I'll at least try removing it in one piece, but my gut feeling is that I'll be attacking it with the angle grinder!
Old 13-01-2007, 03:15 AM   #13
niko
likes falcon's
niko's Avatar
'cos that's just so practical :P nice and safe to ;) (i presume private doesn't live on a farm lol
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 10:43 AM   #14
private9
private9's Avatar
Ahhh.... no!
I don't think I'll be tipping it on it's side.... would make things easier though!
Old 13-01-2007, 10:42 PM   #15
chrispie123
at the middle muffler it sleeves into it should be able to undo clamp there and seperate may take some work but yeh wont be that hard thats way i done in previous
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2007, 11:04 PM   #16
private9
private9's Avatar
Awesome, I'll give that a try tomorrow! If I can remove it without cutting, hopefully I can install it into my EF myself as well!
