fairmont ghia au 2 wagon
does anyone know an easy way of changing the plug leads in an au falcon?
buy one with them already on there......
or get them installed.....apparently on a hoist is easy i cant see how all i did was remove the CAI upto the throttle body and stretch my arm under there and install each individually good luck
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
LPG Forum Moderator
remove the bottom half of the airbox then you can reach your hand in easily to the coil.
#4 | |||
Yeap that is how it's done
I've said it before; hardest thing about it is if it's the first time being done you need to cut some cable ties. After that it's nice and easy. Just do one at a time so you can't stuff it up |
Are they like the EF with the 3-coil pack under the manifold?
I found the first time I tried to change just one lead it was very difficult. Next time I removed the air filter box and found it was easier to remove the coil pack screws and remove the coil pack with leads still attached out through the front. Then changed the leads off the car - easy - then tied long piece of string to each group of leads, passed the string through the gaps in the inlet manifold, and pulled all the leads through as I passed the coil pack back into position, then put the screws back in the coil pack. Much easier! cheers.
1967 XR 289 V8 Falcon (1st) - 1973 XLE 250 4spd Cortina (2nd) 1987 XF GL 4.1 Dual-Fuel Falcon (3rd) - 1996 EF 4.0 GLI Falcon (4th) 2003 BA 4.0 LPG Falcon Wagon (5th) 2016 SZ Territory TX 4.0 Petrol (6th & last?)(Sadly, written off) 2004 WRX (Retirement Toy) |
What are you 5ft nothing?
Because that's the only way it could be easier ![]() Maybe your arms just aren't long enough |
I got someone to feed them down to me while I was under the car, once you get your arm in teh right spot it was easy to do them 1 by 1
SUMP PLUG
I agree, one by one and do it by feel instead of trying to look. I was able to get to them all by taking off the snorkel only, but I have kind of long arms.
#10 | ||||
Want some classic?
XC Falcon, waiting for the Clevo & C4 - Sold AE101 Corolla, the daily - Sold SII RX-7, original - Sold BF II GT Alfa Romeo 156 JTS, the new daily Z31 300ZX Turbo |
i find the quickest and easiest way is to remove your snorkel and fan shroud and put your arm parralel to the rocker cover and under the plenum chamberand pull all the leads off. them feed one through one at a time.. the setup is like so:
34 25 16 should not take more than 10 minutes this way good luck
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
#12 | ||
Takes about 10-15mins doing it the way FalconSR said to.
#13 | ||
Boost Addict
i normally remove the oil filter, makes life so much easier
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#14 | ||
Any difference in plugleads for a standard INTECH in a AU2 and a TICKFORD VCT INTECH in a AU2 Fairmont Ghia ?
#15 | |||
#16 | ||
Ripping it up
yes
the vct uses different leads and plugs |
#17 | |||
#18 | ||
BA Falcon, AUII. R.I.P.
I just changed mine today, easy. get your car on ramps and have a mate feed n swap the new leads to you, while you plug them into the module. it looks a lot harder than it is.
AUII Forte: 18 Inch Tickford Wheels, Pioneer Head Unit, Kicker Speakers, Lowered, Tinted Windows. R.I.P. Current: 2004 BA Silk Falcon Futura Mods: Tinted Windows Wheels: RJR 18" Tremors. Sound: Soon: JVC DV7205 DVD Head Unit, Blaupunkt 480W RMS 4Ch Amp x 2, Polk Momo 6.5" Splits, Polk Momo 6"x9", Pheonix Gold 1500W Mono Block Amp, Earthquake SubZero Subwoofer |
