10-11-2006, 09:50 PM | #1 | ||
Turbo Falcon Fiend
Can it be done? Can I fit an e-series 5 speed to my AU1?
What bellhousing/clutch arrangement do you need?
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
10-11-2006, 09:57 PM | #2 | ||
As far as I know:
Bell Housing needs to be AU. Pedal Box needs to be AU. Otherwise you can still use your Auto Pedal Box. ECU needs to be AU. Clutch Cable will need to be AU. (I think). New tailshaft. The rest should be okay, i.e. clutch, etc. Wait for a second opinion however.
AUIII Falcon Forte, with SIX Appeal |
10-11-2006, 10:06 PM | #3 | ||
apparently they sit too far forward, ie the stock shifter comes out under where the radio sits in an au, i can't comfirm this though, it's only from what i've read on here, apparently you may be able to get around it with a bent gearstick...not sure tho
11-11-2006, 01:03 PM | #4 | ||
Turbo Falcon Fiend
anyone seen the bent gearstick thing work?
Is it cheaper to find an AU 5 speed?
