Old 20-04-2013, 05:51 AM   #1
diatribal08
diatribal08's Avatar
Unhappy AU Doors cycling
Hi guys quick question I suspect its the dreaded actuators my 99 AU 1 when you open front doors you can hear locks cycling , back doors will do same when opened but not when either of the front doors is open ?? anyone had this or similar ? any help appreciated could not find anything using search.
diatribal08 is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2013, 08:38 AM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: AU Doors cycling
one of your actuators is faulty probably a rear one, this is a common fault and it's normally a rear one
[SIGPIC][/SIGPIC]
Rides:
Old 20-04-2013, 08:49 AM   #3
revcore
revcore's Avatar
I always thought the front actuators were the masters and the rears were the followers therfore in theory there would be a high chance of it being one of the front actuators.
Fixing the actuator is pretty easy. The series one had the skinny cog where as the series two and three had the thicker one so if you repair it yourself you need to specify that it's a series one AU that you have.
Also, If your AU is a wagon try unplugging the actuator in the tailgate and see if it still cycles.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2013, 09:27 AM   #4
revcore
revcore's Avatar
Actually, Now that I think about it, The series one and two might have the skinny cog where as the series three had the thicker one, But regardless of that, If you do have to repair your actuator then state that it's a series one.
My Ride...
Old 20-04-2013, 08:14 PM   #5
diatribal08
Thanx guys is there an easy way to tell which actuator is at fault.
Old 20-04-2013, 08:33 PM   #6
revcore
revcore's Avatar
Unplug the drivers actuator then see if it cycles. If it does plug that one back in and unplug the passenger one and do the same until you find the faulty one....Process of elimination.
My Ride...
Old 24-04-2013, 01:09 PM   #7
diatribal08
Will try that on days off and then order from fleabay, also can you program remote when actuator acting up ? ive been trying and not working is 99 AU 1.5 Smartshield have got the 2 button remote...
Old 25-04-2013, 01:36 AM   #8
BHDOGS
just make sure u get the shorter cog for your series 1 when you buy it as they changed them half way through series 2
Old 28-04-2013, 10:33 PM   #9
Aplito Futura
I've got an interesting problem now which is annoying me but liveable. For some reason when i open the doors, the actuators cycle but the drive door doesn't open. Good guess is the lock doesn't lift up from the latch when i open the doors via remote. I went to remove one from a car at the wreckers couple of weeks back and i noticed its comes out with the lock from the particular door. Is that right or was i doing something wrong?? While im here to remove seatbelts from AU(2) Falcons do i need a big fekoff phillips head or can i unscrew it with a socket??
Aplito Futura is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
