28-12-2011, 04:27 PM | #1 | ||
horsepower
Hi guys,
Need your help with this as this is my first time changing the belt on my au2 ? Question is how hard is it too do ? And what do i use to release the tension away from the belts ?? Thanks Futura01 |
28-12-2011, 04:54 PM | #2 | ||
Unplug and remove the fans, then have a look at point #3 from this post:
http://www.fordforums.com.au/showpos...0&postcount=19 Oh, and draw a diagram of the path before you remove the belt, of course. |
28-12-2011, 05:10 PM | #3 | |||
horsepower
Thanks, thought i would have to go out a buy a crow bar !! seems alot easier that way |
28-12-2011, 05:24 PM | #4 | ||
Just remember you need the smaller 3/8" size end, the breaker bar in my socket set is the larger size. You can see in the pic that I'm using a stepdown adaptor. If it wasn't for that extra bit jutting out I probably would have been able to remove the belt without needing to pull out the fans.
28-12-2011, 05:40 PM | #5 | |||
horsepower
29-12-2011, 01:04 PM | #6 | |||
As mentioned, draw a diagram of the path...it's a bit complicated. |
29-12-2011, 01:54 PM | #7 | ||
Be careful with the 4 bolts that hold the fan shroud in. If you use the longer ones from the bottom in the top, you will punch through the plastic tank and stuff the radiator.
I also like to cut up a piece of cardboard and tape it to the radiator so you don't damage the core if your working on the water pump or something else for an extended period. Just a little bit of insurance if your a hack like me. |
30-12-2011, 01:18 PM | #8 | |||
When I removed the fans on my AUIII 'mont there were only two bolts holding them on, and no clips as mentioned here: http://www.fordforums.com.au/showpos...95&postcount=8 |
07-02-2014, 10:51 AM | #9 | |||
07-02-2014, 10:56 AM | #10 | ||
Arranging the belt from the crank pulley onto tensioner pulley was trckiest part, bit fiddly..
Thread Tools | |
Display Modes | |
