Old 19-08-2010, 03:20 AM   #1
redauxr8
Default AU XR8 S3 idling terribly!
Hi everyone,
my AU XR8 is idling terribly and chewing through alot of fuel!
When the car is left idling for a couple of minutes, the revs drop as low as 2-300rpm and if u giv the accelerater pedal a little stab it drops even lower and sometimes stalls. Also, when it idles in P or N u can smell the fuel being dumped out of the exhaust.
Car has 130,000kms. No mods, just twin 2.5 inch exhaust.
I'm guessing could be leads or something? Coil packs are same from factory..... What about O2 sensors or fuel pump?
Any help would be great! thanks in advance
redauxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2010, 09:45 AM   #2
JK EX CHASER
Formally kotevski22
JK EX CHASER's Avatar
Check fuel pressure regulator vacuum hose for leak or cracked.
JK EX CHASER is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2010, 10:07 AM   #3
JC
JC's Avatar
Is the MAF connected? Is it clean? The default state of tune when the MAF doesn't work or is not connected is a very rich base tune, with resulting loss of power, poor idle and lots of fuel being dumped out the back.
Ford Performance Club ACT
Old 19-08-2010, 11:40 AM   #4
xr8ute
Back on the road
xr8ute's Avatar
Start by looking at the MAF, as per JCs comments.
Or even the pipework connecting the MAF to the Throttle-body...maybe its loose and is not airtight i.e. massive vacuum leak.
Old 19-08-2010, 12:54 PM   #5
b2tf
not here much anymore
b2tf's Avatar
Check MAF then 02 sensors.
RAM 1500
Old 26-08-2010, 07:08 AM   #6
redauxr8
Whats the best way to clean a Maf?
Old 26-08-2010, 09:33 AM   #7
JC
JC's Avatar
Carefully. It has a very fine element in it that can break, and then you're in a world of hurt.
But I know you meant what product. Carbie cleaner will do it. Wd40 will work. Even good old metho. But clean it gently and let it air dry (or use hair dryer or heat gun) before you try starting it up again.
Before you clean it though - are you running a K&N filter? Has it recently been oiled? If not, chances are the MAF itself is OK, but check the plug.
If you can get a scan tool hooked up to it to see if there's any codes, that would be the first thing to do. While we can try to help over the net, you may replace or clean etc random parts for no effect, whereas $50 odd to take it to a workshop for a scan tool read and/or diagnosis might end up being cheaper.
Old 26-08-2010, 04:52 PM   #8
adrian k
adrian
adrian k's Avatar
what ever you use it musn't leave a residue. thats what screws them up, so carbie cleaner or brake cleaner, nothing oily, and you are better off not touching it with anything, just use the cleaner and a hair drier.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2010, 05:01 PM   #9
b2tf
b2tf's Avatar
You can get specialist MAF cleaner from autobarn.
RAM 1500
Old 26-08-2010, 06:33 PM   #10
redauxr8
Thanks guys
Old 26-08-2010, 07:28 PM   #11
JC
JC's Avatar
I like their claim - "Proven to gain 4 - 10 horsepower at the wheels".
Thread Tools
Display Modes
