18-08-2021, 07:58 AM | #1 | ||
Hello
I bought a 250 crossflow 6 from a wreckers a couple of months back which i have put in a boat , it came with an electronic Distributor and no coil, the wires where cut from the coil. so what I'm left with brown brown/black yellow/green I'm guessing the Brown is + and the brown /black is _ not to sure what the yellow/green is can someone please give some advise cheers Garry |
18-08-2021, 09:13 PM | #2 | ||
around the place
is it sn XF EST distributor? post up a pic of what you have....
GPS Tracker for your vehicle - PM me for info |
19-08-2021, 07:42 AM | #3 | ||
Hi Coupe
same as this one as attached cheers Garry |
19-08-2021, 08:52 AM | #4 | ||
As far as I can see from those pics, that dissy is an XF EST unit & as such doesn't do much on its own. It is meant to be used with an EST control module (ECU). All it has inside is a hall effect pick-up & no method of advance.
For your boat motor you need a proper electronic dissy out of an alloy head XD, an XE or a leaded XF (pre-1986). It is a complete dissy with full advance mechanism & control module, it just needs an ignition coil & you are right to go. Dr Terry. |
19-08-2021, 10:35 AM | #5 | ||
Thanks Doc
that's all i needed to hear lol ....more money god dam it cheers Garry |
19-08-2021, 12:48 PM | #6 | ||
19-08-2021, 02:20 PM | #7 | |||
Dr Terry |
20-08-2021, 09:54 AM | #8 | ||
Thanks Doc
appreciate the advise given cheers Garry |
20-08-2021, 12:47 PM | #9 | ||
around the place
mate just be careful with those chinese ebay cr@p ones. you will either have issues with the module failing, or the gear chomping the cam.. its very common especially on the singlecam engines cheap dissy costs engines after a few months.
personally id get onto a ford wrecker and see if theres any genuine bosch/motorcraft ones around and get hold of one and rebuild it if needed. I probably had a box full of them, but got rid of all the junk that never got used :(
