26-11-2019, 06:10 PM | #1 | ||
Hi all,
When I use gentle throttle or when I plant my foot the transmission is quiet and smooth as normal, but when I use half pedal etc, it sounds a bit rough, not shuddering, but not normal. Any ideas as to what to look for? Transmission fluid level is ok. It only occurs when in Drive, not park or neutral. |
28-11-2019, 08:30 AM | #2 | ||
Can't think of anything but then it's hard to know what you mean by sounding rough. I presume you've checked for DTC's - does it happen if you do the same with the vehicle held in gear?
28-11-2019, 02:48 PM | #3 | ||
No fault codes, and it does it when i select manual gears as well. It felt like a misfire at first and i changed the plugs, but it only does it when I'm drive, not manual or park so i ruled out the engine.
