Old 05-09-2012, 09:34 AM   #1
Loris
Focus & Territory TDCi
Default Reverse Light Switch Replacement
Hi all,
I have a 2008 Focus TDCi and my reverse light is not working. Took it in for service and they said its not the globe but the Reverse Light Switch.
They had to order the part in which I now have.
Does anyone know how to replace one.. doing some research i believe it is located on the gearbox. Easy to see once the battery + tray and air filter is removed.
Can anyone elaborate further on replacing the switch?
Thanks,
Loris
Loris is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2012, 01:25 PM   #2
fonfe
RS shop's technician
Default Re: Reverse Light Switch Replacement
Just unplug it, pop a socket or spanner on it undo and remove.
Screw in new one, plug back in -job done
Advertising removed
fonfe is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2012, 01:53 PM   #3
Loris
Thanks fonfe.. also just confirming that it is indeed under the battery and air filter?
Old 23-03-2014, 07:31 PM   #4
drez
TDCi Lover
drez's Avatar
I think I have the same problem here TDCi 2008 as well. Tested mine globe and fuse all good.
Looks like a switch problem for me too, did you find any tricky process removing the old reverse switch?
drez is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 10:49 AM   #5
focuszetec
Looks like I have the same issue on our LS Focus. Is the switch in the same location on all Focus models?
focuszetec is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2014, 02:43 PM   #6
marg99
on the TDCI its on top of the transmission at the front get at it from the engine bay
Old 09-06-2014, 09:07 PM   #7
focuszetec
Thanks, I should have said mine is the petrol so I guess I just have to get in and start pulling things out.
Old 14-06-2014, 10:43 PM   #8
focuszetec
Removed the airbox today and was fairly easy to identify the switch on the top of the transmission. Size 22 spanner and I was able to remove it as I wanted to check it out before I got a repalcement. Checked it with a multi meter and the switch appeared to work. Anyway sprayed some wd40 on the connector and put it all back together. Reverse light now works. Could be the switch has somehow come good or the electrical connector needed cleaning.
Old 15-06-2014, 07:50 AM   #9
marg99
sorry to say this but did the same thing with mine twice. and each time it worked fine for a few days then failed again. eventually just replaced it.
Old 15-06-2014, 10:01 AM   #10
focuszetec
Thanks, yes I'm anticipating it probably won't last so will keep an eye on it and replace if it goes again.
