09-10-2013, 03:46 PM | #1 | ||
With da Warlords
Hi all.
Just hooked my xr up too an elm327 scantool using forscan. It popped up with one DTC. RCM - B1877 Code; B1877 - Safetybelt Driver Retractor Circuit Failure Module; Restraint Control Module Details; Wiring Harness Open Circuit. So my question is, what does this mean? And how do I fix it? Also noticed my IAT is reading -15C, think its buggered too lol Cheers, James
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
09-10-2013, 06:13 PM | #2 | ||
it's a seatbelt pre tensioner fault. I had the same but it was just the plug on mine
[SIGPIC][/SIGPIC]
10-10-2013, 09:50 AM | #3 | ||
With da Warlords
So If i pull the bottom half of the pillar where the seltbelt goes, I should find the tensioner down there somewhere
10-10-2013, 10:02 AM | #4 | ||
no, the pretensioner is in the part attached to the seat it is part od the buckle . the connection is under the seat
[SIGPIC][/SIGPIC]
10-10-2013, 10:57 AM | #5 | ||
With da Warlords
Ahhh, cheers for that. Definitely plugged in, so I'll have to check it out
10-10-2013, 12:03 PM | #6 | ||
one might be faulty, if you can get hold of a spare set for testing try swapping them over
[SIGPIC][/SIGPIC]
